RJJ
Hello. My first attempt at rivnutting. I thought I would be a smartass and dodge buying a rivnut tool; I wound it on using a spare machine screw, spare nut and washer.
The first one worked a treat.
The second one...not so much. Gained sufficient compression to hold the rivnut in the mast but not enough to stop it spinning. Grrrrr. Looking inside, the threads are full of claggage; I guess I could clean the threads and try tightening it some more, but of course to clean the threads I would need the rivnut not to be spinning.
What next? Many thanks. Should I cut off the existing rivnut or drill it out,.or is it worth trying to secure it to the mast somehow?
The end purpose is a single mast step about three feet above deck level.
