halcyon
The reason I asked about this, is not because of chatter (which I think is not a problem with the hysteresis curves of modern VSRs) but because I do not like my VSR being already closed due to solar when I start the engine - but because I am worried about start voltage spikes damaging my electronics. Obviously JumbleDuck's solution will not work for this as I need to have the VSR off until after the engine is running. I had wondered about a 'normally closed' relay wired to the starter circuit. Or maybe I am looking for a solution to a non-existent problem?
Fit a normally closed relay in the VSR earth line, connect the coil to the solenoid feed from starter key switch to starter. This drops out VSR before the startermotor turns, connecting to power side can still give a spike.
The hysteresis curves came in in the early 80's, not that modern.
Brian
