Rigging screws
Which way up for rigging screws
  • RH on top
    Votes: 11 73.3%
  • LH on top
    Votes: 2 13.3%
  • Either
    Votes: 0 0.0%
  • Any whichway
    Votes: 2 13.3%
  • Total voters
    15
  • Poll closed .
VicS
13 Jul 2002
Which way up? Is there any convention?
RH thread on top, LH on bottom
LH on top, RH on the bottom
Either provided they are all the same way up.
Any old whichway. Some up one way some the other
On all the boats I've had the rigging screw screwed onto the wires the normal way, screws anti-clockwise onto the bit on deck. So I guess that's right hand on top and left hand on bottom.
Right-handed (ie, normal) thread on the bottom. That way it feels like you're tightening things downwards when you turn it to increase tension.
Not a big deal, though, and I have been known to carelessly mix them up (KS's rigging screws are forks both ends).
Rigging wires I have fitted of recent times has the RH normal thread on a swage on the wire. So no choice RH thread at the top LH thread on the deck fitting. But surely otherwise it does not matter. good luck olewill
Thoughts about rigging screws: http://saltyjohn.blogspot.co.uk/2011/04/turnbuckles.html
Did you know that the right hand thread should be at the top? This means that when you turn the turnbuckle body anti clockwise the stay tightens.
Go on then, you have flatly asserted which way up they should go, but you don't give any reason.
Given the choice, I go for the other way round, because usually when I turn things anticlockwise they loosen, and I don't see why I should make my shrouds confusingly different.
If there is a reason to prefer backwards tightening, I'd be glad to hear it :)
When you are kneeling on the deck looking up at your rigging with the rigging screw in your right hand you will naturally feel it appropriate to turn the rigging screw anticlockwise to tighten it. This may, intellectually, seem wrong because as we all know, lefty= loosey, but I think you'll find that, to most people, it feels right. I suppose that's why most rigging is fitted this way.
But, I'm not the authority on this - you can fit your rigging screws anyway you like.
I understand that the reason for RH thread to be on top in the UK is that UK riggers do not normally have LH threaded "pullers" for their swaging machines. The "puller" is the large nut that gets screwed on to the threaded swage terminal that the hydraulics pull on when doing the swage to the wire. Hence its not right or wrong, just normal for practical reasons.
Thanks for the replies.
I helped step a mast yesterday and fitted all the rigging screws with the RH thread on the bottom. Later when I thought about it I realized that mine, which are spliced onto the wires, are all the other way up.
No big deal I guess but it would have been nice to have done it "correctly" on someone else's boat.
I always thought it should be RH top. RH bottom so it tightens 'normally' is easier and is commonly found, but from the engineering point of view the screw should turn AGAINST the lay of the wire, so there is no risk of loosening the strands while tensioning it.
Whichever, the screws should all be the same way up, otherwise things can get complicated when setting up the rig!
My forward lowers are lefties and all the others are rights...mast can be lowered with an A-frame so it helps differentiate forward and aft lowers when refitting everything prior to restepping the mast
