Guardamar
Active Member
I usually sail a dinghy and have reasonable experience to set up the rig tension. But my 26 ft keel boat is another matter. It has a fractional rig, forestay, caps, lowers and backstay.
Without backstay tension, and with reasonable tension in caps and lowers, the mast minorly inverts till I put on backstay tension. The exit point for the forestay is above that of the caps, but only just, and the spreaders are more or less in line with the caps.
I have tried slack lowers, but read that is bad. Ideally I would like to change the spreader angle a little, but that does not seem easy. It is a comparatively new Seldon mast - perhaps 10 years, and to me appears like a tree trunk.
Any thoughts as to how I can loose power?
I do use a backstay a lot, and have 16 : 1 purchase.
thanks
thanks
