trapezeartist
If a boat has not had the rig tension touched since it was set up six years ago, what (if anything) is likely to have changed? I believe it was all done properly back then.
It's very easy to do. Undo the nuts each end of the bottlescrew, turn the bottescrew until the wire won't bend when you push it and ensure the mast is upright forward/aft and side to side. That's what we do.
Agree, that is what I used to do.
However, I now have a rigging gauge tensioner to adjust my rigging, every season; costs ~£60 and I was amazed with the difference it makes when the rigging is properly adjusted.
I had my rigging replaced a couple of years ago, and the riggers who set it up for me said that very few owners dare to tighten the rigging as much as it should be tightened! When they'd finished, it was a lot tighter than the old rigging had ever been. Probably well worth getting a local rigger to check every few years.
Wklein, there is no set tension force. Selden recommend 20% of breaking stress on the cap shrouds with the backstay hard on and no more than 25% with the backstay off. This is independent of wire gauge. Youngs Modulus of 1x19 stainless wire is such that 1mm extension over 2m length is equivalent to 5% of breaking stress. Therefore you just tape on a 2m length of wood and accurately measure the gap between the end and the ferrule on the shroud. Not as easy as a Loos gauge, but quite do-able with care.
What i was saying was that the rig tune is influenced by:
Spreader length (huge factor)
Continuous / Discontinuous Rig,
In mast / Slab
In lines / swept spreaders
Weight of spar
Hull construction
Raced or cruised
Drift on lowers
Stiffness of spar
Angle of forestay intersection
I think selden were giving a maximum strain for maximum wire lifespan not giving a universal tension for a given wire diameter.
have you actually read the Selden document referred to .
It may not be the ultimate treatise on rig tuning but its gives far more information and guidance than simply giving a maximum strain for maximum wire lifespan or a universal tension for a given wire diameter.
Of course if your boat has a coachroof stepped mast and is not in the first flush of youth you may find that tightening the rigging is merely driving the mast foot through the coach roof or distorting the frame that is supposed to support it.
Been there.....
