VicS
On my rig, the backstay splits just above headheight going to 2 anchor points on the deck. None of the guides I've seen show this arrangement. I've always assumed I tighten the two halves at 10% (aiming for a 20% stretch), is this assumption correct?
Mike
Apologies for slight thread drift.
The splay between the two lower sections of the back stay will mean that you will have slightly less tension than the equivalent of 20% in the upper section but other wise yes you are correct.
A little bit of simple maths will calculate the actual tension required in the lower sections if you really want to be precise about it but since it's all "rule of thumb" stuff anyway hardly worth the bother
