Norman_E
On a post below the instructions given by Selden are recommended. They can be downloaded in PDF format from this web page .
I used these instructions to check my rig after the boat was re-rigged. All the tensions (as checked with a Loos professional rig tension gauge) were much lower than the percentages of wire breaking load recommended by Selden, and professional riggers then tightened everything up for me, but still to well below the Selden percentages. The riggers commented that if they set the cap shrouds at the Selden recommendations I would probably find it impossible to open or close cabin doors. The percentages Selden recommend may work for racing boats, or for boats with rigging of the minimum acceptable sizes, but on a boat like mine where most of the wire is 10mm setting the cap shrouds at a bit less than 10% of break strength is quite enough to keep the leeward shrouds taut in a blow, as has been proved by some pretty strong winds in the last months sailing.
On a cruising boat with a heavy duty rig you will distort the hull if some of the tension settings advised by Selden are adopted.
