nrcoyle
I have a new to me (1984 vintage) beneteau first 24.
I am trying to understand and optimise this rig type to get the best performance from the boat. I suspect in reality it really needs a new suite of sails, but I would like to see what I can do with the existing setup until finances allow an upgrade.
My problem is that I am struggling to find any guides appropriate to the rig setup, as it seems a little unusual. The rig is a 9/10 fractional rig, but the spreaders are netural rather than swept back and the lower and upper shrouds are in line with the mast. Therefore any bend in the mast, as well as tension in the forestay comes from the adjustable backstay, this has a block to give a 8-1 mechanical advantage.
Can anyone point me to any references where I will be able to read more about this setup and get a pointer as to what I should be looking at in terms of shroud tension and backstay forestay lengths/tensions to get the best performance. I suspect at the moment that I have too much sag in the forestay but am not really sure if it needs to be shortened, or if the backstay tension just needs to be increased.
