LadyInBed
Two head sails but on two stays. An inner forestay is much more versatile.
You will need one anyway for a storm sail.
An alternative arrangement is to use the boom as a pole.
Stow the mainsail and run one headsail sheet though a block on the end of the boom, which is then swung out, almost touching the aft lower shroud and set up on a preventer against the mainsheet. The headsail sheet should be taken to a snatch block on the rail near the shrouds and thence to the cockpit winch.
We have two sepaate stays, so I have never tried the twin rig. If you put two sails on a single furler, as in the video, how do you cope if, for whatever reason, you have to turn to windward?
I guess both sails will fly on one side, and one can be dropped behind the other.
Is that correct?
Having thought about it, we never hoisted or dropped one sail on its own as they were both attached to to furler swivel at the top. Changing to one sail meant dropping both.
As I thought. Too much fuss for me, that's why we have to stays close together. We can fly both without poles.
