Ian_Edwards
Hi,
I need to replace the VHF cable to the mast head, so I need about 25m of 50 ohm co-axial cable ( the standard length supplied is 20m, which isn't quite long enough and would mean a joint inside the mast where it is inaccessibly, unless the mast is un-stepped)
The current cable, supplied with the Hawk VHF antenna is quite thin, much smaller than the standard VHF cable I'm use to, which seems to be about 5mm in diameter.
I've tried to identify the cable, but the Hawk website just says RG58, so there must be some additional identifiers to specify the cable.
Does anyone out there know the correct term for "thin RG58"?
