Rewiring thoughts
Stemar
12 Sep 2001
I'm gradually finding out how the wiring on Jazzcat works or, more accurately, mostly doesn't work.
I'm going to scrap the existing ceramic fuses and their holders because I've too many bad memories of grief from them in old cars and bikes, and use blade fuses. Most circuits will go through a master switch so I can turn everything off when leaving. So here are my thoughts so far. I'm thinking that the lead from the battery isolator to the master should be 4mm and have a 30 A fuse and, for simplicity's sake everything else will be 1mm.
CircuitFuseOn Master?Separate switch?
Nav lights
2​
YesYes
Steaming light
2​
YesYes
Deck Flood
2​
YesYes
Anchor Light
2​
YesYes
Interior Lights
5​
YesNo
Fresh water pumps
10​
YesYes
Chargers/12 outlets
15​
YesNo
VHF
5​
YesNo
HH VHF Charger
2​
YesYes
FM radio
5​
YesNo
Instruments - depth, log, wind, plotter
5​
YesYes
Autopilot
5​
YesNo (can just unplug it)
Windlass
5​
YesYes (power to up/down switches at bow that work the relay)
Any thoughts, suggestions, things I've missed?
Thanks in advance
I would be tempted to have a separate switch for everything partly for the sake of uniformity and to be able to isolate things, but maybe because everything electrical on my boat has a separate switch.
Do the volt drop calcs for larger items as Sam suggests; 4mm and 1mm feel small to me. Otherwise seems reasonable.
I like having a master switch for cabin lights - it lets you be sure during daylight hours that there isn’t a forgotten reading light in a corner somewhere draining power all day. Also convenient to turn everything off with one flick as you head out to the pub, and everything back on as you come back. But depending on the size of boat and your pattern of use, those may matter less to you than me.
I agree that there’s no point having a switch at the panel for devices that have their own effective on/off switch. And I approve of the switch for the windlass control circuit; I have the same having once laid on the foot-switch on a charter boat while wrestling with a stuck jib, and had the windlass start grinding away at my oilies…
For what it’s worth, my light, windlass, and deck socket switches are in the cockpit next to the plotter, rather than at the chart table. Not everything electric has to be on a single panel.
I too have blade fuses, they’re compact and simple and the slight extra effort of replacing one rather than resetting a breaker is irrelevant since they shouldn’t be blowing or tripping regularly in the first place. The only time I’ve had to replace a fuse in nearly ten years was when I foolishly left the instruments circuit turned on while rewiring one of the displays.
Nav lights
2​
YesYes
Steaming light
2​
YesYes
Deck Flood
2​
YesYes
Anchor Light
2​
YesYes
Interior Lights
5​
YesNo
Fresh water pumps
10​
YesYes
Chargers/12 outlets
15​
YesNo
VHF
5 10
YesNo
HH VHF Charger
2​
YesYes
FM radio
5​
YesNo
5 10
YesYes
Autopilot
5​
Windlass
5​
Thanks in advance
Most of the wiring and most of the fuses are underrated. The autopilot should have a switch, plugging in/unplugging live equipment is a bad idea.
Use 10mm cable to the panel.
All other cables should be 1.5mm, except the ones i've marked in red, which should be 2.5mm. Suggested fuse rating in blue.
I have assumed LED lights.
Autopilot will depend on the exact pilot and cable run, most definitely not 1mm. 5A fuse looks low for an autopilot.
Double check all other fuse rating, don't fuse too low, for instance, everything except the 12V outlets and possibly the autopilot could simply be 10A, they only protect the wiring.
