Stemar
I'm gradually finding out how the wiring on Jazzcat works or, more accurately, mostly doesn't work.
I'm going to scrap the existing ceramic fuses and their holders because I've too many bad memories of grief from them in old cars and bikes, and use blade fuses. Most circuits will go through a master switch so I can turn everything off when leaving. So here are my thoughts so far. I'm thinking that the lead from the battery isolator to the master should be 4mm and have a 30 A fuse and, for simplicity's sake everything else will be 1mm.
Any thoughts, suggestions, things I've missed?
Thanks in advance
| Circuit | Fuse | On Master? | Separate switch? |
| Nav lights | 2 | Yes | Yes |
| Steaming light | 2 | Yes | Yes |
| Deck Flood | 2 | Yes | Yes |
| Anchor Light | 2 | Yes | Yes |
| Interior Lights | 5 | Yes | No |
| Fresh water pumps | 10 | Yes | Yes |
| Chargers/12 outlets | 15 | Yes | No |
| VHF | 5 | Yes | No |
| HH VHF Charger | 2 | Yes | Yes |
| FM radio | 5 | Yes | No |
| Instruments - depth, log, wind, plotter | 5 | Yes | Yes |
| Autopilot | 5 | Yes | No (can just unplug it) |
| Windlass | 5 | Yes | Yes (power to up/down switches at bow that work the relay) |
Thanks in advance
