PCUK
You can get a bulkhead mounted universal heat exchanger for peanuts if you look around. Just a matter of re-arranging the pipe-work.
Yeah, + VAT and shipping. Haven't found anyone online that repairs them.
If you look at the second line of that web page, it says VAT incl.
If it's the stack that has failed then old fashioned radiator repair shops will be able to help you out. There used to be one in Bursledon. It's only brass, copper and silver solder (?).
There's something odd about this: 4 replacements in 20 years and it's failed again, so 5 failures, so an average life of 4 years. We have one and it's fine - eleven years old now. First I would ask around (here?) how old people's functioning Martec heat exchangers are. I bet the average is more than 4 years.
Second I'd talk to the previous owner (if possible) and ask what exactly was failing in the the exchangers. They have a very small anode inside which doesn't last long - have you checked yours? The anode may be half-gone but the carrier should look newish, a season old, if it has been renewed regularly.
I'd also check that it is actually plumbed correctly. The pipework needs care to route it all to the correct points. And I'd check inside the exchanger to see what has failed, to check that it actually has failed inside.
Finally I'd email Martec and explain about the serial failures and ask them what the probable cause is. Their english will be fine. None of this will cost anything and you will probably get to the real problem gradually?
Many thanks for your comments. The history notes are hand written and a little hard to decipher as much is written in abbreviation. It's possible that replacement of heat exchanger actually means replacement of heat exchanger anode - I can't tell, but that might make more sense. One entry says that the heat exchanger was removed and cleaned at one point.
At the moment the boat is out of the water - and running the engine sees the fresh water coming out from the exhaust. The anode is partially corroded - but there's still loads left, it is stained pinky red - which I'm guessing is from red antifreeze.
I have found a company that might be able to renew the stack for a much lower price than a replacement.
Do you mean that the red coolant is coming out of the exhaust? I assume you are cooling the engine with a flow of water somehow if running it ashore?
