Reverse Polarity
AllanG
5 Apr 2005
Hamble, UK
I want to use my Honda EU10i generator to charge my batteries onboard my Legend 306, however, when I connect the generator to my shore power socket, the Reverse Polarity light on my boat's main switchpanel comes on.
I have checked all the shore power wiring from the socket to the electrical panel, as well as the lead from the generator to the shore power socket, and all are correct, i.e. live / neutral and earth are correctly connected.
Can anyone shed any light on where the problem lies, could the generator 240V outlet socket live and neutral be incorrectly connected?
It should be noted that there is no polarity problem when the boat is connected to a marina shorepower, using the same cables.
Any help would be greatly appreciated.
Many thanks, Allan
savageseadog
19 Jun 2005
It might be because the generator itself isn't earthed. There should be a terminal to connect the generator to an earth which is either a metal spike in the ground or a metal plate in the sea.
tangofour
2 Aug 2006
Sussex/kent border
There is no physical difference in an AC signal to make one Live and one Neutral.
I suspect that your generator does not have its Neutral connected to the frame ground ( for vey good reasons ) so your reverse polarity detector detects the floating Neutral.
AllanG
5 Apr 2005
Hamble, UK
It might be because the generator isn't earthed. There sould be a terminal to connect the generator to an earth which is either a metal spike in the groung or a metal plate in the sea.
As my boat is kept on a buoyed river mooring, is there anywhere on the boat that I could earth the generator to?
AllanG
5 Apr 2005
Hamble, UK
Does this mean that I could still use the generator safely onboard to charge my batteries, even if the Reverse Polarity light is lit, or should I try to earth the generator, (if possible)?
Flossdog
8 Oct 2006
West Wales
Am really interested in the replies as I am about to purchase the Honda EU10i and am trying to justify the huge price diff with other gennies. Apart from the above problem, would you recommend this gennie Allan?
shmoo
23 May 2005
West Cornwall
Are you quite sure about this. (In UK at least our) supply is not "balanced". Live is, well, live and neutal, well, isn't.
Try measuring voltages between Live and Earth (expect 240V) and then between Neutral and Earth (expect a few volts do to voltage drop back to substation)
savageseadog
19 Jun 2005
[/ QUOTE ] Yes Neutral is usually earthed at the nearest transformer, technically Neutral doesn't exist until this earthing is done, so there is a considerable difference between Live and Neutral. I think, however, the point was being made that the generator is free floating so there is no difference between live and neutral. Which is why the reverse polarity light is on. The panel is detecting that there is 240V to it but nothing from live to earth.
tangofour
2 Aug 2006
Sussex/kent border
The Honda generator is a plastic 'suitcase' type, naturally there is no way for the unit to be 'earthed' unless an earth spike or something is employed. If an earthing point is provided ( cant see from the honda website ) I would make sure that it was connected to the earthing system of the boat. Otherwise I can see no reason why you cant just use the 'reverse connection' light to let you know that the genny is still running /forums/images/graemlins/smile.gif
nedmin
12 Oct 2002
north lincs.
you could connect a flexible cable to the earth point and other end to a piece of copper pipe with a jubilee clip and throw it overboard.the copper pipe I mean!this wouild give you a good earth point.
AllanG
5 Apr 2005
Hamble, UK
Apart from this slight 'problem', the Honda EU10i is an excellent gennie, very quiet running, and I would thoroughly recommend it.
AllanG
5 Apr 2005
Hamble, UK
When I asked my local Honda generator dealer this afternoon about this problem, they said that all I had to do was to 'link' the Neutral terminal to the Earth terminal inside the normal three pin UK outlet plug.
I would appreciate your, or anyone elses, opinion about this solution? Would it be safe?
Gumpy
12 Dec 2006
A far corner of Little England
I have done this on my genny.
It is safe provided that Honda say its OK as some gennys get a bit upset if you do this.
Do you have an RCBO/RCD fitted in the boat system if not its better to leave it as is and ignore the light.
Julian
