nigelmercier
RIP
- Joined
- 20 Jun 2007
- Messages
- 16,234
- Location
- Live in Kent, boat in Canary Islands
I should be using a Neon with virtually infinite resistance.
Until it strikes, at which point it becomes a low resistance, and curiously negative.
I installed the GI due to heavy wear of the anodes on the Hamble, a common problem I am advised. However, by installing an led rather than a neon indicator I may have defeated the whole point if fitting it, the led with its voltage dropping resistor effectively allowing a short circuit straight past the thing. The AC PD is virtually nil, but I am seeing nearly 3 vdc across the GI, designed to stop Galvanic DC voltages below 6v, so seems to me the GI is trying to do its job, just that LED short is allowing the upstream shoreside connection for neutral to earth to effectively completely bypass the GI, which would explain why I saw little benefit for having it last season.
Indeed...it still does not explain why you can measure such a high DC potential difference across the GI.
... I would not remove the GI, just find out where the earth leakage is coming from. Do you have a RCD / ELCB?
This is a very common problem and is probably caused by the shore supply cabling. A simple test is to get the boat next door, or on the same pontoon, to put a large load on their boat. If they run a kettle and fire and your Reverse Polarity LED lights gets brighter then the fault is the pontoon AC supply.
This may not be an actually fault, but the result of lots of boats on the pontoon using lots of amps and causing a voltage drop along the cables feeding the pontoon. If you've not noticed this before in your marina it could be caused by a lose connection somewhere on the neutral cable feeding your pontoon. It may take the marina a long time to admit to any fault!!!!!
At the marina transformer the Neutral and Earth are bonded together. With large currents down the cables there will be a voltage drop along the neutral wire which may get up to 5 volts or more by the time it gets to your boat. There will be no voltage drop on the earth cable as there is no current flowing, so there is now 5 volts between the Neutral and Earth which makes the LED glow. This can cause earth leakage breakers to trip so you will keep losing power.
You should measure the voltage between the neutral and the earth cable. It shouldn't go above 5 volts AC. When there is a full reverse polarity it will have 240 volts across it and shine brightly.
I didn't understand a word of your post. Please translate into English. I've googled CPC and TT and still don't understand! PD I get but others might not.I can see where the potential difference is coming from and agree with some of the thinking. But what can also happen where the voltage drop is after the the neutral to earth bond point is that you can get a significant PD between this system earth and true earth causing all the CPCs on the system to have this PD on them. As an aside if you have bonding in place on your boat between shore CPC and stern gear, swimmer would be exposed to this PD as there would be a voltage gradient around the stern gear. It would be unlikely to experience such problems in the UK as marina systems would be TT and have there own local earth.
I didn't understand a word of your post...
Sorry I know exactly what you mean about abbreviations it can make it very hard to read if you dont know what they mean. CPC is circuit protective conductor, earth wire in old money. TT is an electrical system, with its own earth steak and usually with RCD protection, all the CPCs of this system are connected to this earth steak. It can be a stand alone system or part of a larger system that has an earth from the mains distribution system. But in all cases the earths from other systems should not overlap, otherwise one system can export fault voltages to another system
TT is an electrical system, with its own earth steak...
My earth to earth PD across the GI earlier this week was just over 2vdc. Is this excessive or am I chasing ghosts here ?
Anyway I have removed the offending LED, and will install a neon instead for reverse connection alarm...
The whole point of this post was that a false glow warns you that there is a problem with the shore power. Our Legend has LEDs. The LED was not your problem!A neon will only light up at the designated voltage i.e 240, so will not show a false glow due to a few volts PD occurring from a loaded neutral,......
A neon will only light up at the designated voltage i.e 240... I might imply opt for the plug in tester, and do a simple check each time a attach shore power.
Investigations this weekend on my home mooring reveal a more promising picture and at least one significant likely galvanic leak has been traced.
The PD across the GI was much reduced from the 2.4v at Weymouth down to a more acceptable 0.15v. So I suspect the shore earth may have been dodgy
Views please !
