ShipsWoofy
I apologise for jumping too fast and I was rather unfair to you in this instance. In defence I can only claim that it can be frustrating on here when a person takes the time to answer a quite specific question and the OP (original poster) never shows up again; Was the problem solved, did the OP even come back to see it? These are things we never find out.
It is not fair on you, but most often this happens from people who join the forum on the day of asking and their post count never passes 1.
I am sorry I put you in that category, but when there was still no response to my posting I did think, uh oh, here we go again.
___________________________________
I fitted faria counters to my two 1GM10 engines, these work exceptionally well and are quite easy to fit, as I have said before on here, to add a wire to the Hitachi alternators fitted to the 1GM10 is about 2 spanners if we use Haynes manual terminology.
To fit a faria you will require the counter, a capacitor and wire, the counters and capacitors are available from ASAP
Click for link. I used FAR32842 which will come up when searched. Then add 708194 to the search window to find the capacitor you will require.
In the meantime may I point you to the alternator cct diagrams for yanmar Hitachi alternators and another pdf for a similar alt-sensed rev counter that will give you an idea how it all works.
hitachi 35A alternator PDF FILE
hitachi 55A alternator PDF FILE
Useful tacho manuals (these help with calibration, when you are ready to set them up)
TAH-97026B.pdf
TAH-97029N.pdf
If you do go this route and when you have the components I will be happy to assist in the wiring to the alternator and any other questions you may have.
Sorry again for the misunderstanding.
TAH-97026B.pdf
TAH-97029N.pdf
