Retour a La Base
flaming
24 Mar 2004
Most of the TJV IMOCA fleet leave Martinique tomorrow (29.11.23) on the Retour a La Base Vendee Globe qualifier. Including Le Roi Jean, whose new daggerboard boat wasn't ready for the race out. This one’s a solo race. Into Biscay in December….
See Pip's recent video. They've put gates in that they can finish the race at if the conditions dictate the fleet not wanting to close the shore.
dunedin
3 Feb 2004
That’s a good call, particularly with boats that are too deep to enter most harbours, and many only at HW (though hardly surprising, as the guys who organise the IMOCA events are super professional).
John_Silver
19 Mar 2004
St Mary's Island
allatseawithstargazer.blogspot.com
Things hotting up in the Retour a La Base: Alex Thomson's 24 hour distance run, for an IMOCA, looks as if its about to fall; Pip's got an oil leak on the keel hydraulics; Sam Goodchild still at the sharp end of the fleet; Sam Davies working her way up the rankings; Le Roi Jean yet to cross the start line (which closes on the 7th), but has arrived in Martinique and is fixing some shakedown issues, from the trip out.
Bigger breezes to come (very big for anyone too far north) over the next 48 hours......
dunedin
3 Feb 2004
And that’s the first boat, Paprek Arkea already arrived. Just 9 days and 3 minutes is a decent delivery trip “back to base” in France from the Caribbean! At an average speed of 19.7knots. Not bad for his first time sailingnthe boat solo! Yoann Richomme (Paprec Arkéa) wins inaugural Retour à La Base solo Transatlantic race
Sam Goodchild is also doing fantastically well in 3rd place with just 130 miles to run, as are Sam Davies and Pip Hare currently 6th and 11th but in very tight races with other boats nearby
John_Silver
19 Mar 2004
St Mary's Island
Some great shots (from around 20 mins in) of how well the Conq / Koch hull shape surfs the swell. With Yoann swooping round the tip of Groix and in, under the walls of the Citadelle de Port Louis. Even off the foils, the forward third of the hull seems to be just lightly skimming the surface.
dunedin
3 Feb 2004
I may be wrong, but these look like taken after the finish, or at least after stopped racing, with the sail reduced to slow down to chat on the foredeck. In racing mode one of the bigger jibs/asymmetric would be set - and would be sheltering in the protected cockpit. Can’t go on deck without crawling when at speed in waves, as taking solid water at 20+ knots.
Bobc
20 Jan 2011
Amazing job by Sam Goodchild. Sam Davies still looking very strong in 6th, and Pip in 11th but coming up from the south.
Looks like a tough last day for Pip though. Big swells out there.
dunedin
3 Feb 2004
And Sam Davies has done it - across the line in a brilliant 6th place, having fought some very serious completion every mile of the way, Holding off the hugely experienced Louis Burton on Bureau Vallee in 7th place must have been very hard work.
Go Pip Hare
Zing
7 Feb 2014
Yes, these are amazing achievements and a fantastic technological step forwards in boat design, but I feel a kind of disappointment. These are not real boats. They are something else, a sort of aircraft/windsurfer/ sea skimming thing. I can't see the technology spinning off onto normal cruising yachts or to anything I aspire to own. Good luck to them though.
dunedin
3 Feb 2004
On the contrary, look at many / most modern cruising yachts and you will see masses of things that are more similar to a 20 year old IMOCA, Class 40 or Mini then to a "traditional" cruiser.
From wide, semi scow bow, through wide beam, to very wide stern, twin rudders etc.
Also wide shroud base, low friction rings for sheeting, sometimes fathead mainsail etc
flaming
24 Mar 2004
..,,and Pip’s ahead of Clarisse, on the ex-Apivia now L’Occitane….
Whilst I'm obviously very happy about this, I think for Clarisse and certain others who currently have low qualification miles, finishing the race is so much more important than pushing. So it may well be that she has more pace than she's demonstrating.
If she dropped the rig, for example, she'd really struggle to qualify for the Vendee.
