fredrussell
New boat came with sprayhood thats in ok order apart from the cracked and worn out clear PVC window material. I've found a great tutorial from PBO online, and it looks a straightforward process.
There seems to be two gauges of PVC used most commonly, 0.5mm and 0.75mm.
Cost is not a deciding factor as its a small boat and I'll only need 1 metre off the roll, so less than a fiver difference between the heavy and medium duty stuff. Obviously I would assume the heavier stuff is the one to use, apparently its UV resistance is greater. My sewing machine is a old-school Jones domestic machine that has its own gravity field due its extreme mass - so I'm confident it'll deal with the heavier gauge stuff if required to.
Is there any other factor I need to be considering? Do you get better visibility through the thinner gauge PVC? Does one or other gauges crease more easily? Any other considerations?
