Miker
Last sail of year today. No wind so hammered engine for 7 miles. Not a sign of a leak! Will winterise then see how it goes next year.
The oil leak occurred when not heeled. I will be replacing the oil filter so could have a look at the reducing valve. Found the pressure reducing valve in the workshop manual. Presumably I would need a replacement seal if I take it out to clean. Also I do not know what torque required for reassembly. The manual gives 60-70 for the relief valve and 35-39 for the pressure valve holder.
No, not the oil pressure relief valve. There will be a breather arrangement on your engine, whereby suction from the inlet manifold draws fumes from the crankcase. There is usually a simple spring-loaded valve that opens when the crankcase pressure exceeds a certain (low) value, drawing the fumes into the manifold, then closing again. If this doesn't work for some reason, usually carbon accumulation, the crankcase can pressurise and oil will be blown out of the seals.
I will leave the relief valve thingy well alone. Thw workshop manual mentions crankshaft ventilation but gives no details.
I cannot find any parts for a crankcase breathing system on the parts lists although there is a "separator" and a "filter" in the rocker cover. That must be it I think.
Slacken the oil filler cap carefully to see if there is any pressure under it. If there is much then investigate the filter and separator.
All the workshop manual says is,
"Crankcase ventilation
To prevent overpressure and to separate fuel vapour,
steam and other gaseous combustion products, the engine
is fitted with enclosed crankcase ventilation."
It sounds like it may be similar to the Bukh one. On the 20 there is a small drilling (about 5 mm) through the head, finishing inside the air passage on one of the cylinders. This connects to the crankcase for the purpose of drawing fumes out. There is no mention of it in the workshop manual and the drilling is not shown on any of the drawings I have seen. Over time this drilling blocks with carbon deposits with the result that the crankcase over-pressures.
I was wondering what parts 32 and 33, described as "separator" and "filter", were. At first I thought they would connect with a hose but #35 is just a plug not a hose nipple
