Thanks to anyone who's replied to me before on this topic.
I'm going to replace the 3000 odd lbs of wet, rusty, scrap, loose steel ballast in the keel of a Colvic Watson 26 thats causing the hull to be permamnently saturated...........I know - I'm crazy but otherwise the boat's fine.
My feeling is that poured concrete will be best, then when it's set paint it with something waterproof or probably better to skin it over with GRP attached to the hull sides to seal it in for ever and form the waterproof bilge floor.
Can anybody suggest:
1 How does this idea sound? Any alternative to concrete?
2 Anybody done it?
3 Might the concrete chemicals affect the hull fibreglass when drying. I thought of laying thick DPM polythene in there first.
4 Any suggestion on the mix to use - I assume the mix should be as dry as possible to reduce curing time and shrinkage.
5 How important is it to get the total weight exactly right and also distributed in the right place fore and aft ?
6 One big lump or divded up say by polystyrene spacers so it can all "work" a bit once it's set.
7 Add some steel reinforcement ?
The name of good psychiatrist may also be useful later.
Malc Davis.
2 Anybody done it?
Malc Davis.
