Zhivili
Dear All,
Despite being only 18 months old, our engine sea cock has broken in that it is permanently in the closed position. I think that the shaft leading from the handle to the ball valve has sheared.
I would appreciate advise as to whether I can change this sea cock whilst still afloat. It is only 18 months old and I am sure will release easily.
Has anyone, for example experiance with freezing the spigot of the inlet pipe. You can get freezing kits, used in the plumbing world, but do they go low enough to freeze sea water ? Alternatively, does a bit of sea water in the boat matter much. Can you take the sea cock off and then quickly put a new one on ? Would a new one have to be prepared with jointing compound (in which case I can see a problem). Alternatively, would a rubber "O" ring or washer between the spigot and valve seal properly.
Local engineers tell me that we have to take the boat out, but being at Port Solent, this is going to be very costly.
Would appreciate any advise on taking a sea cock off, whilst still on the water.
Thanks all.
Thanks all.
