Dessa75
Hi - I am about to replace the reefing line pulleys which are mounted on an "axle" or pin running set into the gooseneck fitting (this arrangement is probably common and not sued only on Dehler 36s). The axle/pin runs transversely through the cast gooseneck and appears to have some sort of inserts at each end of the hole to presumably prevent the axle from dropping out. Has anyone had experience with removing this axle/pin? Rather than attacking it with a large hammer and punch, I'm interested to understand what these inserts are made of - how do you remove them - does the axle/pin then come out without a fight?
Thank you
Thank you
