mickyp168
I have a 23' sloop. The main sheet is getting a bit tired and worn , I expect it is the original so its about 30 years old. It is fitted on a system I believe is known as a 'fiddle'. 2 blocks of pulley's under the end of the boom, the bottom one fixing onto a fitting on the floor of the cockpit. Should be simple to buy the sheet and fit it to the pulleys. However the sheet is fitted to the bottom pulley by having been sewn in a loop into place by the manufacturer . Looking at it, if I cut the loop out to remove the sheet there isn't room inside the pulley to fix on a new sheet with a bowline, so it probably needs to be re sewn which wont be easy. So I thought I buy the whole system with the main sheet in place already . However cant seem to find such a thing trawling though lots of websites. I am wondering if its possible to source such a thing, or am I missing some point about just replacing a sheet onto the original blocks. Thanks for any good advice.
Mick
Mick
