Sandmartin
Did this on a boat I bought 20 years ago. Cut the internal GRP cover away to reveal bolt head, then, using a basic welding kit, spot welded a bar to the bolt head.
So, how does the bolt get corroded when the water that is corroding the heads is in the bilge and the bolts are encased in the GRP and then the keel?
If you have ever seen corroded keel bolts you will know that the corrosion occurs where the bolt enters the keel where water has come from a failed joint, not from under the head downwards. Corroded heads are common in boats with mild steel bolts or nuts and leaky so water rests in the bilge. It is not a good indicator of bolt failure.
Lots of boats change heads with rusty keel bolt heads - goes with the territory on boats of this type. Clean it up, rust prevention and paint and try to keep dry so it does not get any worse.
Lots Of "possiblies" there - hence the earlier advice to ask the surveyor why he thinks they should be withdrawn when an earlier sample proved OK. What has changed in 4 years? There won't be any crevice corrosion as they are mild steel.
They will probably be M20 bolts - takes an awful lot of corrosion to have any impact on strength of such a bolt - even if the head is corroded. The washers (or more likely plates) will be substantial and bet that even if the exposed parts are corroded, the bit under the bolt head will be fine.
If some of the heads are corroded to the point where they are difficult to remove, I would replace them before they are impossible.
Exactly.
Would you grease the replacment bolts before insertion or what?
(Mine has encapsulated keels, so this is just out of interest)
I removed a couple of my old bolts which had rusty heads. Absolutely perfect everywhere else, you couldn't know they were half a century old. I needed to use a cold chisel to get the nut off but it didn't take long. I replaced like for like and the new nut is already a bit rusty like the old one. I think a bit of rust protects it! My bilges are a bit wet, as in always got some sea water in them. (Wooden boats, love em!)
On the one hand, I'd rather have the hull-keel join in compression to do the job.Many thanks for these replies- very thought-provoking!
Before I take any action I'm going back to the surveyor to establish his reasoning for the recommendation. I think he'll say it's to do with age of the boat, the state of the bolt heads etc. And then I'm going to concentrate on the 2 corroded heads, which happily are above the same bearing plate. If I can get the 2 out I'm going to replace that plate and the bolts - even if it shows no corrosion along its length i.e. no evidence of water penetration at the keel/hull joint. I plan to do this without lifting out as there are - from memory -10 or 12 bolts in total.
Does that sound a reasonable way forward?
