louisderry
Hello all,
I currently have a fishing boat that has been totally gutted it is a bilge keel boat. The bilge keels were attached using m6 roofing bolts made from steel. They had rusted completely so I removed them all and dropped one of the bilge keels. I've rebedded the keel with a sealant and added m8 A4 stainless steel bolts with a 2p size washer - 14 in total. the orignal plan was to have squares of teak wood on the inside then a washer then a nut but due to the wood cracking when tighting the keel bolts iv'e decided to stick to bolts, washers and sealants only.
I can't decide if I should glass over the top of the bolts as well or if I should fibreglass over the keel on the outside also. Am I over cooking? obviously the keel needs be solid and withstand impact??
Will a good sealant /adhesive and m8 bolts be okay or should I glass ?
