HarryFlashman
New Member
Hi,
My name is Morgan, from near Welshpool in Mid Wales. Always been interested in boats and this year obtained a very sorry looking Longliner, but fortunately with a sound hull.
I found my way to this interesting forum when looking into sourcing a replacement rubbing strake for an early 16ft Orkney Longliner. I was hoping to buy one direct from Orkney, but on closer inspection the factory strake they sell, is designed to fit over a lip, where the top and bottom sections of the boat meet.
My boat is definately a Longliner, but does not have this lip - instead it has a cutaway into the hull. I don't think the lip has been ground away by a previous owner. Scanning the net for Longliner images I have seen another like this too. Mine currently has a rotten wooden strake - perhaps I should just go for another wooden strake ?
If I use a commercial aftermarket Pvc or rubber strake, will any of these bend around the bow and the transom corner, without having to use end caps - as these are quite pricey and it would look a smarter job.
If I go for wood - what would you recommend - I might be able to get hold of some Western Red Cedar - or would you suggest a hardwood. I would have thought it needs to be about 50mm wide, but how thick would you go ?
Many Thanks
Many Thanks
