PuffTheMagicDragon
Hauled out last Monday and found that one blade was split to almost 3/4 of the chord and the other blade showed severe dezincification towards the root. Definitely a case for replacement, the problem is with what size.
As far as I can make out, the diameter appears to be around 15 inches but I have no idea of what the pitch is or was. I could not identify any markings on the hub; hardly surprising as it is 39 years old. The motor is an old Volvo MD2B with an MS gearbox at a 1.91:1 reduction. Maximum engine revs are 2500RPM. Fingers crossed, I do not anticipate replacing the engine any time soon and so I need to buy a left-handed prop (a new engine would probably take a RH prop).
Does anybody here know what size prop was originally fitted on a Centurion 32? Should I stick to a 2-bladed or should I go for 3-bladed? (shaft is on a P-bracket and is offset to port by the side of the skeg).
As always, TIA for any information that you can give me.
