VicS
Regarding the cable size
If I am reading the electrical installation instructions correctly they seen to advise using cable which is 8 to 10 mm diameter
TRICOLOR “QUICFITS”, COMB. TRICOLOR / ANCHOR “QUICFITS”, MASTHEAD “QUICFITS”, COMB. MASTHEAD / ANCHOR “QUICFITS” The electrical connection of these lights is only made in the “quicfits” base. Use round cable of about 8- 10mm dia. with adequate cross-section. Loosen the cable clamp. Dismantle about 35mm of the cable according to ill. (9) Feed cable through cable entry and cable clamp parts. Arrange electrical connection according to ill. (5) and fasten cable clamp with two screws. The installation should be done according to this instruction in order to ensure a watertight closure of the cable gland. Electrical connection of light and “quicfits” base is obtained by pushing the light onto the
Presumably to suit the cable entry gland ??
3 core Ocean flex 1.5mm² is smaller than this . 5.9mm according to FR
