Seastoke
i want to have oil psi and temperature gauges on the fly bridge ,they are both electronic ,where can i get gauges from ,thanks roy
You'll need the same make and type as you already have otherwise the sender won't work. Also unless you have dual output senders already you will need a simple change-over switch to switch between wheelhouse and flybridge.
This is not necessarily the case. If you can find a scaleable gauge that doesn't place a load on the sender then this could work. The Noland module converts analogue data being read by a gauge of any scale to NMEA2000 to input into a plotter display. I can't see why this would not work on a scaleable gauge device, just need someone to point out such a device.You'll need the same make and type as you already have otherwise the sender won't work. Also unless you have dual output senders already you will need a simple change-over switch to switch between wheelhouse and flybridge.
Aren't the Wema gauges compatible?
No there not with the Vdo senders, vdo do a nice range and I can assure you they work with Volvo senders .
Yours are VDO , temp and oil gauges approx £45 each plus vat , you will need new senders as wellmine are perkins engines but dont know what make the gauges are
hi paul are there senders that will do two gauges then
