steve yates
The yard had a look at my tank while she is in pembroke, and reckoned it would come out fairly simply for cleaning and painting, but of course it didn't. The only way to get it out is to cut it up.
They cleaned it in situ, as best they could, and got a lot of black sludge and rust out of the bottom of it, sadly it was that sludge that was keeping the deisel in. Any fuel put in starts leaking from various rust holes! So she is stuck there till I sort a new fuel tank.
The issue is; in situ is a 110l tank, and a custom built tank, that can fit through the access aperture of 455mm sq, can only hold approx 70l.
(450mm sq, for clearance, and max 385mm high (current tanks height) to allow for the connections between tank and cockpit sole.
The max depth here available is 520mm between the bearing and underside of the cockpit sole.
The other alternative is a standard plastic tank 350mm w x300mm h of 42l capacity, and maybe use two of these with a connecting valve, (I understand the renowns have port and stb tanks? )
It seems a retrograde step to replace the tank with a smaller capacity, but unless I want to start chopping up the cockpit, it seems like my only alternative.
I have been quoted around £650 for a custom tank and around £250 for the 42l tank, plus fittings, plus labour.
My questions are, has anyone here successfully replaced a tank on a longbow, and what with if so?
Has the combined experience here any ideas for getting a larger fuel capacity into that space?
And does anyone know of a source of premade tanks at better prices.
I have already emailed tektanks, as quandry suggested them as an eventual replacement when I got the boat.
Thanks.
Thanks.
