Replacement breaker indicator wanted
Boo2
13 Jan 2010
Hi,
Just been connecting up my new Lofrans branded windlass circuit breaker and found I had no joy. I've traced it to the LED inside the indicator, the breaker itself seems OK so far (tested without load). The supplied indicator comes apart and comprises a red LED (3mm dia) with a 680 ohm current limiting resistor in red plastic indicator tube around 6mm dia having an 8mm end "cap" and is around 18mm long, see pic below.
Maplin sell LEDs that seem suitable replacements here : http://www.maplin.co.uk/p/5mm-red-led-ck48c which looks to be the right diameter and does not need a resistor to run off 12V (max reverse voltage only 5V though :eek:). I could use one of those but I would really rather just buy a replacement indicator if possible, anyone know where you can buy such a thing complete ?
If they are a standard part, please let me know what they are called 'cos I've drawn a blank so far in my search.
Thanks,
Boo2
Have you tried searching for "12V LED indicator"? That finds me http://www.maplin.co.uk/p/8mm-panel-mount-green-with-plastic-bezel-led-n02bb at Maplin and a spectacular number of things on eBay. Narrow it down to "12V red led panel indicator" and you find things like http://www.ebay.co.uk/itm/Warning-L...Lights-Lamp-Oil-Classic-Car-12v-/111094143540 and http://www.ebay.co.uk/itm/Neon-Indicator-LED-Plastic-Various-Types-/380857882345.
Hi JD,
Yes, I did search as you suggest but, as for the ones you kindly uncovered for me, I found lots of wrong-sized and wrong voltage types. The indicator has to fit the 6mm hole in the Lofrans windlass breaker mount plate so it needs to be the dimensions I posted.
Thanks anyway,
Boo2
Just to update : I went for the LED from Maplin's and have repaired the indicator. The LED I bought *can* stand 12V reverse bias at least briefly (DAMHIKT :o). I'd still like to buy a replacement indicator though, if anyone knows a source ?
Boo2
