Tim O
Hi
Any ideas where i might source some replacement slides for my boom main-sheet and kicker attachments.
The picture shows the main-sheet attachment - the screw which should hold it in place is entirely rusted away (but of course impossible to remove) so a previous owner has used a piece of rope tie to the back end of the boom to hold it in place.....not ideal though effective!
There is a spare one nearer the mast, so thinking to swap it I attempted to undo the kicker attachment and the spare one and found both of those the fixing screws are also immovable.....all probably due to stainless screws in alloy components causing galvanic corrosion??
![IMG_4352[1].jpg IMG_4352[1].jpg](https://ybw-data.community.forum/attachments/22/22038-e593e04411b99474408dc08df0109549.jpg?hash=5ZPgRBG5lH)
Also as you can see, the "strip" type shackle has worn a groove into the slide so would prefer to replace if possible
