infaddict
Hi, I am replacing some very old and corroded Blake's seacocks with Tru Design composite ones. The Blake's are secured with 4 bolts so when removed I need to fill these 4 holes. As they are below the waterline it's super important they are filled correctly. I have a solid fibreglass boat and hull.
My plan was to sand/rough up the insides of the holes using a Dremel tool, then put some masking tape over the outside of the holes. Then mix up some thickened epoxy, probably with some silica or chopped strand. And fill the holes.
Is this a suitable repair strategy for under the waterline? Any advice appreciated thanks.
