Capt Popeye
Repairing /Replacing the INNER foam core ; is this possible at all ; My boat has been declared Non Repairable by a Fella because the Inner Foam Core he says , is soft and faulty (irrepairable?) Is this so ? Is it possible to make holes in the Inner PVC skin and inject suitable foam into the cavity between the outer and inner skins ?
The Boat is advertised as Unsinkable because this Inner Foam will give boat sufficient Boyancy by excluding Water from accessing tween the hulls ?
From my observations , many Boats do not have an Inner Core of Foam , they rely upon the Outer Skin being water tight , ie no holes in it ; plus a Bilge pump or two for the Spray and any other water coming over the sides ?
Thanks CP
Thanks CP
