FairweatherDave
The stanchions have been removed and some soggy balsa removed..... its a Westerly......
Q1. I was going to simply fill the holes with thickened epoxy and redrill the holes for the stanchion bolts. And use butyl. I was going to just widen out the cracks back to solid fibreglass. But would the thickened epoxy constitute an adequately strong repair or should I be bridging the cracks with fibreglass matt, ie making a small patch? Really not sure whether to just go for thickened epoxy as a repair that will cope with compression loads but not necessarily leverage if the stanchion gets abused. (been reading the West system download).
Q2. Deckplates and backing plates. To spread the load I was going to reuse the backing plates which I think are aluminium. I have also seen stainless sheet rectangles used directly under the stanchions. That looks really good structurally but is it overkill. Opinions or pointers to more detail on backing plates and deckplates would be great. (I did read one suggestion of using chunks of premade fibreglass as backingplates, so I'm on the look out if anyone is local to Brighton.....).
Thanks for any replies.
