KenMcCulloch
I have several 1" square steamed oak frames (clinker built boat, mahogany planking on oak frames) that deserve to be repaired in due course.
Several options appear possible. Completely removing the existing frames and steaming or laminating new ones is certainly possible but presents many problems, for example fastenings at the gunwale are inaccessible without taking the deck off which is not sensible.
Sistering with new pieces steamed or laminated to fit alongside the damaged ones, extending above and below by as many planks as access allows would be a strong repair and relatively straightforward to do. Several frames have been strengthened in this way at some point in the past. I know some people argue that sistering just sets up problems for the future by introducing new hard spots in the hull, I'm not convinced this would be a major problem. Aesthetically it's not too appealing although most of the work would be in fairly rarely-examined locations.
Another possibility would be to cut out the cracked section and scarf in a new piece extending say 2 planks either side of the point where the cracking happened. The scarfs would be fastened with epoxy and the nails & roves through the planking. This would be a neat solution, as strong as the existing 60 year old frame and if done neatly almost invisible once slathered in bilge paint, but is clearly a good deal more laborious than sistering, making up the new pieces not too difficult but cutting the scarfs in the existing frames accurately would be quite time consuming I think.
What does the panel think?
