MattS
I noticed that one of the screws holding the bilge pump strum box to the bilge floor has come loose. The hole looks like it might have stripped, and has cracked a little around it anyhow.
It doesn't look like the screw was previously applied with any sealant etc. so I'm guessing that on the rare occasions that water has collected under the cabin sole it could have soaked into the fibreglass a bit.
I have no idea whether there is any kind of wooden core in the hull of the boat, or if it's solid fibreglass? There was certainly some fibrous material that came out with the screw.
On the assumption that I need to do a 'proper job' to make sure the strum box is attached properly and that the screw hole is sealed, what steps might I need to take?
My starter for ten:
- Make sure the hole is left exposed and kept dry for as long as possible (there's no massive rush to reattach the strum box I don't think)
- Fill the hole with something (epoxy?) - maybe I need to drill it slightly larger before doing this?
- Drill a pilot hole in the epoxy for the screw
- Re-attach the strum box, using some sealant around the screw to try and seal what hole is left
Does this sound right?
Anything else I need to consider or check?
My starter for ten:
