moresparks
Hi – I have removed some cockpit panels to send them away for recovering which has allowed access to my stern cleats. However I noticed that the cleat bolts were pretty well corroded and the ply backing panel wet and coming away from the fibreglass. So I decided to remove the cleats.
Now the funny thing was, that the cleat was mounted on a stainless steel sheet, self tapped screws into the fibreglass, so I removed the stainless sheet.
I have now discovered to my horror a mess and which can only describe a botched repair as it looks like at some stage the cleat has been torn out and “repaired”. The “repair” has several cracks in it with several gelcoat star cracks.
I have only limited access to behind the cleat via an access hole and the ply backing panel is still stuck fast in places.
I am thinking of completely removing the botched repair which will probably leave a large hole and allow the removal of the ply.
I am thinking of starting the repair with a thin G 10 sheet as a backing before building up layers with fibreglass and resin finishing off with gelcoat and a new backing pad. Does this sound like a good way forward as the area is reasonably flat?
I have used fibreglass before and still have the tools and various handbooks when I bonded in some engine bearers on a previous boat but not repaired a hole before.
I welcome suggestions.
