lpdsn
My motor operates correctly, and when I short out the slow speed contactor the winch turns indicating the problem is with the contactor/solenoid. This is a Mac 15 made in Italy. It appears only the Mac 10 is currently available but since these were meant to be repairable I am thinking of taking it apart and cleaning the contacts. Is this simple?
Also, I see on a 10 year old post on the Dehler forum that a gearbox seal has to be regularly replaced. Anyone know about this?
I haven't seen that about the gearbox seal. Never replaced mine and given how inaccessible I've found the motor I suspect no previous owner has. Rudolph_hart may know more as he's gathered a lot of detail on these winches.
I'm not sure what you mean by 'contactor'. I'm guessing not the terminal posts on the motor as you'd be a braver man than me shorting those out. I presume you mean the push button. In your previous post you describe the solenoids as clicking, but it sounds like you no longer believe that.
All the electronics/electrics for mine as held in a Harken junction box. I'm sure it can be opened and components replaced or cleaned if spares are no longer available. What voltages are you getting?
