Mudisox
Understand the need to feather the edges but by how much?
Just so. 20mm thick grp at 15:1 would be a 30cm scarf all round. A total of 60cm x 46cm repair. Do you have access to all of that area? And does the internal side of the reair need to be flush?Depends on the nature of the repair.
If you need to re-create a strong sheet with properties near-identical to the original, you might be talking about a scarf angle of 15:1.
If you can overlap a thicker repair, then a much smaller join area can be strong enough.
If you are just filling a hole and the repair does not need to contribute much to the structure (e.g. filling a redundant sea-cock hole), very little grinding away is needed.
