Petronella
We need to repair Petronella's forward bobstay connection. This will mean taking the bobstay off where it meets the underside of the pulpit.
The question is how to do this with as little disturbance to the recently tuned rig as possible bearing in mind this is a wooden mast and that there is a lot of tension on the bobstay?
We have two forestays right next to each other, one with furler, the other unused. Two corresponding backstays. Also an inner forestay with running backstays. At present she is out of the water.
One suggestion is to weight the pulpit down with anchor and chain and then tighten inner forestay and its running backstays. Then loosen main backstays taking some tension off the bobstay and finally unscrew the bobstay bottlescrew. Will this work? Are there any inherent problems with this approach? Is there a better way? The less we have to mess about with the rig the better but the main objective is to not crack or bring the mast down.
