Removing Volvo 290dp-e drive with pics
KevB
4 Jul 2001
Kent/Chichester
Thought this may be of interest to anyone thinking of removing their 290 outdrives for the first time.
Last weekend I removed my 290 drives to change the bellows, oil and give them a good antifoul. Armed with Instructions supplied by Pendana and my rusty tool kit I set to work.
Notes courtesy of Pendana
Outdrive service:
The UJ bellows and exhaust bellows only need changing every other year according to Volvo. Inspect and replace if necessary.
To renew the UJ bellows you will either have to remove the drives or separate the upper drive housing from the intermediate housing.
At 60 kg, the sterndrives are heavy and awkward, however I usually remove the drives each year so I can clean, antifoul and top up with oil in the comfort of my garage at home.
While the sterndrives are still on, remove the props and old ring anodes. Protect the shafts by wrapping something like polythene round them - they are covered in grease which attracts all the dust in the boatyard. Remove the bar anode at the base of the transom shield and keep to put back on if ok.(usually get a couple of seasons out of these)
Remove the oil drain plug with impact screw driver and check that the oil runs clear and not emulsified thus proving the integrity of the seals.(Volvo recommend renewing the oil every year)
To take the sterndrives off, take the weight onto the skeg with timber blocks and folding wedges. Remove the cover plate and release the gear selector cable.
Undo the bolts to the steering helmet clamp (6 mm allen key or hex socket) and remove the clamp by screwing in the long coverplate screw.
Push the steering helmet up as far as it will go.
Swing the drive starboard remove the left bolt securing the gear selecter cable clamp, swing the drive to port and likewise remove the right bolt <span style="color:red">(Mine only had one bolt) </span> and recover the clamp plate that secures the selecter cable. Pull on the cable to esure it is free to move through the hole in the drive.
Undo the jubilee clips and release the UJ bellows, exhaust bellows and water intake hose from the drive. (flexible screwdiver with 7mm hex socket required to remove jubilee clips) <span style="color:red"> (I managed this with just a standard screwdriver with no problems) </span>
Remove the split pins and clevis pins from the forks.
This bit really needs two people.The two pins securing the drive to shield can now be removed. These can be drifted in but is sometimes difficult to recover them from between the forks and the steering helmet. Much better to screw in a 6mm bolt into the end of the pins which are threaded for this purpose and pull the pins out using a slide hammer puller. <span style="color:red"> (I 'drifted' them out ie hit them with a hammer and a short extension bar from a socket set. First you have to remove the securing bolts)</span>
Take the weight of the drive and ease the drive backwards so the UJ separates from the engine output shaft and carefully ease the gear selecter cable free from the drive.
Putting the drives back on is the proverbial reverse order but you have to line up the holes in the forks to the holes in the shields at the same time turn the UJ joint onto the splines of the engine output shaft. This is best achieved by placing the skeg of the drive onto a piece of timber arranged as a lever that you can stand on to raise the level of the drive to line up the holes of the forks with that of the shields. Oh, and it is quite normal to bang your head on the underside of the bathing platform!
Just a postscript to the sterndrive servicing. It is important to get the positions of the screwheads of the jubilee clips in the right location otherwise damage to the bellows can occur.
The clips should always be tightened from the starboard side of the drive.
The UJ bellows clips should have the screwhead at the transom shield end at the 3 o’clock position and at the drive end at the 6 o’clock position.
The exhaust bellows clips should have the screwhead at the transom shield end at the 2 o’clock position and at the drive end at the 6 o’clock position.
The water hose clip should have the screwhead at the 2 o’clock position.
Parts required:-
UJ bellows
Exhaust bellows
Ring anodes
Bar anodes
Plastic bushes for forks
o-ring for drain plug
o-ring for dip stick
fibre washer for filler plug
waterproof grease
My foot note is that so far it's been very easy and I am very glad I gave it a go. Time will tell if I still feel the same putting them back on.
It took me up to a couple of hours to take the first leg off having not done it before but less than an hour for the second having already done one.
All in all it has taken me more time to clean the legs and the transom shield than it has to take the legs off.
Hope the above helps someone.
Kevin.
Would also add that a Halfords 11mm ratchet spanner makes replacing the clip that holds the gear cable MUCH easier.
Well worth it!
Let me know if you find an easy way to line up the splines on the UJ & input shaft!
Good pics, looks like everything went to plan.
Just put my drives back on this afternoon.
Have found the easiest way to line up the holes in the forks and transom shield is to place a plank under the skeg. Offer the drive up to the transom shield as square as possible such that the forks drop in between the ears of the transom shield and the selecter cable goes through the hole in the drive. Fumble (can't think of a better description) with the UJ inside the bellows so that it engages on the engine ouput shaft by about 2mm and get a helper to raise the plank and drive slowly as you place a little torque on the UJ. As the holes come close to ligning up, the UJ engages fully and the holes line up in the foreward/aft plane. You can now concentrate on lineing up in the vertical plane. Drive the pins home with a rubber mallet making sure the cutout in the pins for the lock bolts is at the bottom.
Hope it all goes well.
Eddie
Excellent description of a poxy job,bit scary the first time,studied indifference the second,vague feelings of what will need fixing the third time ,O christ this has got to be done every " £$%^&*" other year.
Shafts here we come....
Ps.Have fun cleaning out every tiny nook and cranny that Volvo built into the transom shield and no you are not allowed to just paint over them tiny and awkward to get at barnycules in the corners.
Ahem, penultimate photo showing suspension pin being knocked out, is that the UJ bellows and water intake still attached /forums/images/graemlins/shocked.gif oops
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Eddie
Eddie
Hah, they were all undone and lose and came away when I pulled the leg off. /forums/images/graemlins/tongue.gif
You can see the jubilee clip for the bellows is dangling.
A good post.
Just a couple of things, on fitting the new UJ bellows don't forget the correct orientation of the wire spring inside the bellows and on the exhaust bellows there is the marking for engine end and a TOP on the flange.
When fitting the cable retaining plate, if you bolt it on the leg, almost nip it up just so that it stays in the up position, you can thread the cable through then just lower the plate onto the cable and tighten up rather than struggling to fit afterwards.
Grease everything on reassembly.
I use a trolly jack to support the out drive, it works for me OK.
I hope this maybe of some help.
Please help... We've removed the drive and the trim cylinder pins will not come out with heat and when 10,000 psi grease gun is applied. We are in process of taking the transom shield off. Everything has been unbolted on the inside. Does something have to be done on the outside (ex. take the large flange w/ 6 bolts and striker plates off) for the shield to come off? Nuts, snap rings? inside the flange? Thanks.
