Robert Wilson
What would you imagine stops the stock spinning within the rudder blade
I wondered whether there might be a "square section" inside the rudder. But probably not enough grip/leverage.
PM me when you find as in #10
Probably shall be the case, so await my PM!
If I was a gambling man, which I'm not, I would bet that there is some way of removing the bottom bearing from the skeg, then dropping the whole rudder and shaft down through the bottom of the hull. Might require the boat to be raised in a crane/boat lift in order to get enough height to drop it though.
That seems to be the more supported conclusion. Looks like it's a "file 'n' scrape" job. Height is no problem as the boat is on a cradle on a trailer.
I shall report back when the dirty deed is done.
Thanks to you all.
R
