Baddox
I want to replace some stainless steel through-hull fittings at the next lift-out. They are ¾ and 1 ½ inch fittings which I expect won’t release by unscrewing and will be a little too tough to use a step-drill on.
Are there better alternative methods of removal to consider before attacking the fittings with a grinder?
My approach will be to stuff a wet rag into the fitting and slowly remove the flange with and angle grinder, hoping that the rag will keep the temperature of the metal down enough to prevent overheating the fibreglass.
