Keith-i
I'm re-bedding the acrylic panel in my Goiot roof hatch which started leaking a little while ago. I've removed the pane but need some method of cleaning all the old sealant off the aluminium frame before I put it all back together with fresh silicone glazing sealant. Is there arny tool or chemical I can use which won't damage the anodising on the frame? I've scraped as much off as I can with a chisel but the irregular casting of the surface makes it impossible to get a clean surface.
