Plevier
I want to remove the fixed 2 blade prop from my boat which has a standard Beneteau 25mm taper shaft with key.
I'm wondering what torque the nut is likely to be and how much of a job it normally is to get the prop loose from the taper? I'm fitting a Kiwiprop and that specifies 20lbs.ft, is the original prop nut likely to be similar tightness?
Puller? Heating? Bronze/brass drift (I don't like that one - it will shock the gearbox - but our local engines man suggested it)?
What I normally do with car taper joints is hold a weight one side and hit the other side sharply. That normally jars them loose. Does that work with props?
Experience based advice appreciated!
