tomski
Progressing with my BR 42 project, I have found a total of 8 rust spots on average about 5 inches in diameter in each case so nothing terrible...and the steel an inch or so away from the spots seems to be very solid...there is also a fair bit of surface rust on the deck (stantion bases, bollards etc) and one of the hatches needs to be replaced...
So I think the two options to me are... first to only spot repair what is rusted, then carry out an ultrasound to ensure that the rest is ok...the second is to remove all paint back to bare metal and start again, fix what's rusted, prime her etc...
End state is that I will epoxy her to a smooth finish but want to make sure she will be done properly so I'm leaning towards removing all of the pain to bare metal and primer her properly
In doing so my question is what is the best and cheapest method of doing that...the options that I think I have are:
1. Grit blast - expensive and probably not possible due to the amount of boats around mine
2. Sanding - with a proper sander and 40grit paper, sand the whole thing down
3. Angle grind the paint off - not sure if that's an option? someone suggested it but I'm worried about the dints it may leave behind
4. Heard about high pressure water removal - works like grit blasting but not sure if that is an option either..
I have some paid labour help which isnt expensive so if sanding is the right method then I can get the chap to do it for me over a course of a couple? of weeks...but wanted to hear your opinions
