Removing old varnish from awkward corners?
owendov17
23 May 2002
Essex
My 1947 built Vertue has a great many fiddly varnished corners and hard to reach crooks and nannies.
It is not possible to get a sander or scraper in to them. The use of varnish remover does not seem to have the same oomph it used to.
Last year a bloke came to Mersea with a sand blasting kit and removed anti foul with great accuracy and skill.
Has any one come across a small DIY spot sand blaster that can be used that will not blow a hole in the old girl.
If you can get a small scraper in you might have some success with a hot air paint stripper. Certainly used with care on open spaces it makes life dead easy, so might work in awkward corners.
A sand blaster would remove the softer grain leaving a ridged effect I'd guess - no good. As well as other suggestions consider broken glass ( held in a leather glove ! ); choose the edge that fits the corner best and discard when blunt.
