William_H
I am just starting to try to debulk the a/f build up. I have used Jotun Seaguard Antifouling paint for many years.
Now many recommend a scraper to remove the build up. I have found various scrapers useless as they just skid over the paint surface. I imagine seaguard might be a hard a/f. Also I do not have that really big build up I have seen on other boats. So using wet sand paper seems the only option.
I have always done a lot of in water scrubbing so a/f lasts about 6 weeks before first scrub. I am fussy about a clean hull and fouling is fierce here with warm water and lots of strong sun. So usually by the time winter haul out comes much of the a/f is gone. However there is a build up at the water line about a brush width wide that I am determined to cut back.
Two ideas seem to work best at the moment. One is a sanding disc on a battery powered drill. The drill has 2 speed gear box (much recommended) so disc turn fairly slowly. I use course sand paper and spray the paint with water and dip the disc in a bucket of water. It takes the paint back and with a fair bit of blue mud everywhere. Biggest problem is the drill battery does not last long.
Second trick was that I had a sand paper belt for a belt sander. This proved really easy to hold in one hand inside the loop and easy to move around to a clean piece of sand paper. The paint rinses off easily. But my arm gets tired.
Fortunately I have the boat at home and about 3 months to do as much as I can of paint removal. But on the other hand the centre section of the hull is a devil to get under when on the trailer. Drop keel is not so hard as the hull itself.
olewill (just looking for sympathy)
