bluedragon
Anyone know if using a heat gun would soften an epoxy coating on wood and reduce the bond strength sufficiently to strip it? A hatch has suffered water ingress at the front and rear edges and this has spread under the epoxy coating, lifting it in some areas. This is easy to get off in strips using a scraper, but in the dry areas it's stuck like you know what! I could power sand it off or leave it on and feather the edges before recoating, but a far neater job would result if I could remove the coating cleany from the wood. Solvents, strippers, etc, won't touch cured epoxy, so I can only think of heat. I wondered if anybody has tried this?
